does anyone know what would happen if you tried serato scratch timecoded vinyl with VDJ?
thanks
thanks
geposted Wed 01 Feb 06 @ 3:44 am
it's working but no needle droping
geposted Wed 01 Feb 06 @ 4:01 am
You get sound. Only sound.
Wherever you put the needle, The place in the song will not change.
The sound quaility is POOR. I can't stress that enuff. It really sounds like some sh1t.
The tempo is MUCH slower.
Like I said... You get sound but it's not worth it and you can't make it any better.
Stick to VDJ tcv's
Stick to VDJ tcv's
geposted Wed 01 Feb 06 @ 4:43 am
DJ quickhands,
It's a good thing to search in the forums for an answer. In that way you could find more information and a solution that could fit to what you are looking for and you can learn more in that way about VDJ.
This answer is ALWAYS the same. VDJ is only COMPATIBLE with VirtualDJ TCVs or D-Vinyls 2020.
geposted Wed 01 Feb 06 @ 4:12 pm
