Hello the team; first of all please excuse the possible faults; this is a computer translation of French towards English.
Suggestion for the future versions:
It could be interesting to steer samples towards the third exit(release). The problem there that by assigning them towards both main exits, the sound is superimposed if both cursors of earning are activated, and anyway the volume is different as the level of cursors. Samples are also played during chains and thus as cursors vary!
Clax
Clax
geposted Tue 11 May 04 @ 5:57 pm
You probably need to translate this one again. Samples currently have a level control.... the problem you say is not clear.
geposted Tue 11 May 04 @ 8:44 pm
What he means is :
The samples are actually sent to the two channels where the decks are sent too, so if you set very different volumes on each deck, or if you add sum effects, a part of the sample's sound will be distorted as well. In this cases, it's not so easy to set the level of the sample. If VDJ send the samples on a third channel, no matter the volume has changed or what effect is on...
FRUiT94
FRUiT94
geposted Tue 11 May 04 @ 11:00 pm
Thanks for this translation Fruit. That's exactly what i wanted to say.
Clax
Clax
geposted Wed 12 May 04 @ 6:29 am
sounds good to me
geposted Wed 12 May 04 @ 1:42 pm
If a 3rd channel was used maybe there could be seperate fx on that channel?
geposted Mon 06 Sep 04 @ 3:04 am
It is possible now since version 2.00
You can select the card/ouptut of each sample if you want.
geposted Tue 14 Sep 04 @ 9:25 am
its avaliable in the advanced sound confic menu
geposted Tue 14 Sep 04 @ 1:24 pm
Thanks for answering but this post has no future ... because it was about 1.08.
geposted Tue 14 Sep 04 @ 3:38 pm
A bit late, but good!
Loved the "cursors of earning" - that's a boiled down version of a softjock/mousejockey eyh??
Lol!
Lol!
geposted Thu 16 Sep 04 @ 8:50 am
