below ur name when u logg on u can download the version of VD but in mine it doesn't have the link any clues.
geposted Thu 16 Feb 06 @ 6:49 pm
how do you get the full virtual dj ?
geposted Thu 16 Feb 06 @ 7:23 pm
you go here http://www.virtualdj.com/purchase/
Nikki
Nikki
geposted Thu 16 Feb 06 @ 9:12 pm
the link is there for a limited time, if you need to redownload VDJ again try http://www.virtualdj.com/contact/
geposted Thu 16 Feb 06 @ 9:38 pm
CAN I RECORD MY VIDEO MIX ?
geposted Thu 16 Feb 06 @ 10:07 pm
@SQUEEZEEYE: You can't record your video mix in VirtualDJ, you need an external source, like a DVD Recorder, a VHS Recorder, or another computer that has a capture card.
Also you can record with your own computer if it has a capture card ,but I guess you'll need a very fast computer for that.
geposted Fri 17 Feb 06 @ 2:40 am
ok i see thank you
geposted Fri 17 Feb 06 @ 4:27 pm
whats the difference between home and pro?
geposted Fri 17 Feb 06 @ 9:14 pm
Difference between demo-home-pro could be found here:
Ewout
Ewout
geposted Sat 18 Feb 06 @ 5:22 pm
