Topic: I found Turntable and Mixer
TheTurkPRO InfinityMember since 2005
hey i found a turntable NUMARK TT200 DJ TURNTABLE
Description:
DIRECT DRIVE
STRAIGHT ARM
BATTLE AND CLUB STYLE DESIGN
REVERSE CONTROL
HIGH-TORQUE MOTOR
33-45-78 RPM CONTROL
STEEL TOP AND RUBBER BASE
DETACHABLE POWER AND AUDIO CABLE
do you think that i can use the timecoded vinyls with this TT
I also found a mixer BEHRINGER DX052 2 CHANNEL DJ MIXER
Description:
BPM COUNTER
ULTRAGLIDE X-FADER
CURVE CONTROL
XPQ STEREO SURROUND EFFECT
X-FADER REVERSE SWITCH
2-BAND KILL EQ (-32DB)
PFL FUNCTION
MICROPHONE INPUT
do you think i can conect this to my comp?
There not proffessional but im not either so im just begginer. so its all good if i can do all these things
geposted Sat 18 Feb 06 @ 7:33 pm
i really need to know anyone?
geposted Sun 19 Feb 06 @ 2:28 am
Dj XeoPRO InfinityMember since 2005
what are you going to use as an audio device?
do you want to use TCV?
what else can you get hold of in your area?
ive got some numark TT500s and they rock, cant get anything better for the price in my oppinion. and behringer tend to be a safe bet. german design, chinese manurfactue. plenty of spares cause theyre popular and if there was a problem you should be able to find out about it on the net (search the product + review on google to see what people have to say about it)
geposted Sun 19 Feb 06 @ 3:00 am
oh yes i want to use TCVs with the TTs im using but i also want to know if i can also hook up the behringer mixer to my comp...
geposted Sun 19 Feb 06 @ 3:17 am
for TCV you'll need a good ASIO soundcard I recommend the ESI U46DJ which will work well with TCV.
Best Regards
DJ White Devil
geposted Mon 20 Feb 06 @ 3:01 pm
djcityPRO InfinityMember since 2005
Hey Turk...
The mixer is cool but you may want to step up the tt's to the Numark 500 instead of the 200's
the 500's are better quaility and more durable.
As for hooking up your tt's and mixer to your cpu, the maya44usb is a good soundcard. The gigaport is a good one too and the esi u46dj is also an excellent choice.
good luck
geposted Mon 20 Feb 06 @ 10:17 pm
what about 2 Dual Stanton STR8-50 professional turntables w/ mixer.
geposted Tue 21 Feb 06 @ 2:02 am
I personaly am NOT a fan of Stanton tt's.
my advice would be...
Do NOT get gemini TT's
Do NOT get Stanton TT's
Do NOT get lower end Numark TT's
Do get Numark TT500 or TTx
Do get Technics
Do get Vestax
For me the other Tt's are just a waste of money
The other Tt's are not BAD per se, it's just that you want something that will last and be able to grow with you.
What good is a TT that you can't play on when you do big shows with BIG sound?
Lower grade Tt's can't cut it at larger applications because you have alot more feedback through the tonearm and the base of the turntable causing a hum that blocks out the music and there is no way around it than to turn the volume way down or turn the bass way down.
Good luck friend...
geposted Tue 21 Feb 06 @ 3:45 am
DJcity is absolutely right. Don't buy a non-professional turntable and expect professional results. That is just crazy, like buying a Hyundai and expecting Ferrari performance. The professional tables are made to a.) sound good in a professional environment and b.) withstand the rigors of DJing day in and day out.
The anti-resonance features in pro tables are especially important when playing in the club. Think about this when buying the tables you plan to use.
geposted Thu 23 Feb 06 @ 7:09 pm
