Forum: Old versions
Topic: Mixman DM2 with Virtual DJ?
Can I use a Mixman DM2 USB digital music mixer to control Virtual DJ?
geposted Sun 19 Feb 06 @ 5:27 pm
JeremKPRO InfinityModeratorMember since 2004
With the provided midi drivers yes you can.
geposted Sun 19 Feb 06 @ 7:28 pm
Have You done it before can you help me do it What MIDI Drivers...etc....etc... Any Help Would Be Greatly Appreciated
geposted Thu 10 Aug 06 @ 5:12 pm
djxzilr8
you will need a program that converts dm2 signals to midi. I am not sure I can mention it here. search google for dm2 to midi. After that program is installed you can assign dm2 controls in vdj.
@beatfreaker
Demo or crack users cannot use this feature.
geposted Fri 11 Aug 06 @ 12:20 am
djyo-coHome userMember since 2006
I have a problem with mixman and virtualdj: When I move the wheel on the controller, in vdj are the waves moving in only one way. I think the problem is, that the wheel sends in normal position a code 65, not zero. Do you know any program, wherewith can be the code overwritten, and can give the wheel negative value???
Any Idea??? Pls help!!! I must till then work with traktor 3! :) thx
geposted Fri 18 Aug 06 @ 11:25 am
OK so I downloaded DM2 to MIDI. And it brought up a program that shows the DM2 that I have. Now how do I get my DM2 to work with Virtual DJ 3-4? Please someone give me a step by step plan.
geposted Sun 15 Oct 06 @ 10:11 pm
