I am really sorry to bother you again for the same
thing, but this is my issue that really needs a
solution.
Is there ANY possible way that I could myself disable
the pop-up window in your plug-in, or could you make
one version with the removed code for that window?
Would that really take you that much time?
I mean, the low freq. slider with the combination of
resonance is a great combination to make a good brake
add effect. But since this 2 have to be applied at the
same time, I cannot have the efect enabled before the
brake. Thus having the (still) inevitable pop-up
appear. That means that while I move the low freq.
slider I cannot disable the effect by pressing the
shortcut, because of that pop-up that makes Windows'
"on top" mode. The problems I than usually encounter
are late breaks with the audio clipping that is caused
by low freq + resonance combo. And no, I don't have
two mouses to lower them both at the same time... :)
So I beg you again, please please please make a way
to disable this thing. Or at least ensure that the
shortcuts would work even if the window is on top
(though I doubt that this is possible).
Sorry 4 the trouble and thanks again!
Regards, erXon
solution.
Regards, erXon
geposted Tue 18 May 04 @ 4:45 pm
I will consider that, but I am really busy by now, so please, be patient ;)
geposted Fri 21 May 04 @ 5:35 pm
Take your time, I will be patient (no problem), I just needed your conformation for solving this problem:)
Thank you very much!
Regards
Regards
geposted Fri 21 May 04 @ 11:38 pm
