Forum: Wishes and new features
Topic: lossless best format compression decoder.
Hi,
it's easy to add in virtual Dj :
a flac decoder
and wavepack decoder.
they are already compatible with nero et winamp and mediaplayer (with a directshow codec)
There are the best lossless codecs around here .
In the nest update ?
A+
Olivier
geposted Thu 02 Mar 06 @ 3:37 pm
erxonPRO InfinityMember since 2003
Is it not possible to add this manually under Settings > Extensions?
geposted Thu 02 Mar 06 @ 4:31 pm
apopsisdjPRO InfinitySenior staffMember since 2003
If media player can play these files on your pc via installed codec, you can create flac and (wavepack); extensions and assign these with "General windows media audio decoder"
In options->extension tab
geposted Fri 03 Mar 06 @ 9:43 am
hi,
i know that.
But i want that virtual dj has his own "built in" flac and wavepack encoder.
(like mp3 decoder and wma decoder)
geposted Sat 04 Mar 06 @ 2:33 am
SupaconPRO InfinityMember since 2005
I concur that this would be a handy addition, although perhaps not terribly high priority.
I have lots of FLAC files, but I usually convert them to either MP3 or ogg Vorbis.
Now that I've pretty much given up on BPM studio, I can also give up on MP3 :) BPM was the last thing that (still) didn't support ogg Vorbis.
geposted Tue 20 Jun 06 @ 6:28 am
