Topic: Automatic Mixing Questions
DjGazUKPRO InfinityMember since 2005
I like to use the Automatic mixing feature, but here's a few questions I have....
1. Is their a way to sort the list by BPM ?
2. How do I edit the "Fade Entry Points"? Or turn them off? I'd prefer the songs to start from the beginning and fade out at the ends, at the moment it cuts off most of the tracks too early or starts them half way through.
Cheers
geposted Sat 04 Mar 06 @ 8:26 pm
djcelPRO InfinityModeratorMember since 2004
1) in the playlist, there is a bpm field but it's hidden, you have to move the columns 2) Force fade=enable +fade_length=0
geposted Sun 05 Mar 06 @ 1:25 pm
Isn't the answer to that on like page 1 of the manual?
Not to slam you dude, but take an hour and read it. I know the answers to your questions, and most likely others you'll have, will be in the manual.
geposted Sun 05 Mar 06 @ 6:39 pm
What manual? I got the program as a download. It didn't come with a manual. Thanks for your help anyway :D
geposted Sun 05 Mar 06 @ 9:16 pm
geposted Mon 06 Mar 06 @ 3:48 am
Oh the humanity!
geposted Mon 06 Mar 06 @ 4:20 pm
