Since I'm new and doing a search came up with an error message...
Where/How do you start doing remixes?
Do you all buy the instrumentals/accapellas then mix them with vdj?
Or, can vdj break down your existing cd's into inst./accap?
Or do the pro's use studio software like pro tools to mute out the diff channels?
geposted Wed 08 Mar 06 @ 11:22 pm
Hey...You have to use instrumentals and acclapellas. Or you can simlpy cut the bass out of one song and run an instrumental behind it.
You can't mute out the instrumental or the vocal of an existing song. you can cut the bass or highs like I mentioned but thats about all you can do.
Hope this helps
Hope this helps
geposted Wed 08 Mar 06 @ 11:42 pm
