Forum: VirtualDJ Skins
Topic: Rotation of Disc.
HaywardPRO InfinityMember since 2005
Is there a way to stop the disc(s) from rotating on certain skins?
Can I modify the xml to do this?
geposted Tue 14 Mar 06 @ 5:40 pm
Yes,just remove the "visual" entry for custom>rotation or custom>transparent or both for both decks in the xml file.
geposted Wed 15 Mar 06 @ 1:16 am
Thanks it worked, also the program now seems to run a lot smoother.
I stopped the discs from spinning, but kept the arm movement.
Maybe the spinning discs should be an option for Minmium spec machines.
Thanks again.
geposted Thu 16 Mar 06 @ 6:09 pm
xeonPRO InfinityModeratorMember since 2004
"Thanks it worked, also the program now seems to run a lot smoother." Is that true????? Only because of spinning discs? :))))
geposted Mon 10 Apr 06 @ 5:03 pm
I can't offer any proof but you can certainly try it and let us know what you think.
geposted Mon 10 Apr 06 @ 7:26 pm
JeremKPRO InfinityStaffMember since 2004
Getting the spinning of disc off, does save a little bit of ressources.
To prove this, take the default skin, play a track on each deck.
Put the TK Filter V2 effect on a slot and activate it
now change the parameters of the effect by moving the mouse. You will see the visual will be a bit choppy.
Now try the same with for example the Dac3 skin, or even VMIX 3.
The Effect visual will run much smoother.
geposted Mon 10 Apr 06 @ 7:46 pm
Thank you Jeremie. I have laptop optimized just for VDJ and i want the best performance i can get from it :) Afterall i am going to buy new laptop :)
geposted Thu 13 Apr 06 @ 3:04 pm
