Topic: Video Output question
advrklHome userMember since 2006
I need to know if you can get the VIDEO Program monitor by it's self ,on on my wide screens, using VDJ 3.2. I can get the output from the Toshiba Laptop S connector BUT I get the entire screen . ( preview of players 1&2 etc.)from VDJ I just need the final mix on the wide screen
geposted Wed 15 Mar 06 @ 7:53 pm
JeremKPRO InfinityModeratorMember since 2004
This is possible with full version.
You have to have the second screen in Desktop extended mode. Then in VDJ Video settings you have to select the correct video output and it will work in full screen.
But again, this is only possible in full version.
geposted Wed 15 Mar 06 @ 8:07 pm
Yes you can. Your video card must support dual output, and you have to configure windows for dual output. Your software will be on the laptop, with the preview window, and the final mix will go out to the big screens. You have to have a registered copy of the software, to do this. I don't think it works on the demo. Are you an unregistered, demo, or cracked version user?
geposted Wed 15 Mar 06 @ 8:20 pm
