Topic: PROBLEMS WITH VDJ AND EQ'S EFFECT
Hi everyone, I have a little problem here, everytime i used the 32 band eq on VDJ it plays like a second of the song that was previously loaded.
For exaple: i"m playing with the player A a song, and i have the eq effect on in both decks, then i load up a new song on player B and when i launch the player B it plays like a second of the song that was previouly loaded, then the song i just load it start playing, is this has to be with having the time streach option on ?
This has happenes on my laptop, I know it doesn't have the best performance to run VDJ at its best, PIII 1.2 ghz, 768 mb ram , external USB sound blaster live 24 bit, but i also do it in my pc, P4 HT dual 3.0 ghz. 1 gb ram, sound blaster live 24 bit sound card, and the problem continues.
can someone help ?
thanks.......
geposted Fri 17 Mar 06 @ 1:10 am
djcelPRO InfinityModeratorMember since 2004
Yes it's a known bug in the plugin and it's not linked to vdj, only the author can correct it
geposted Fri 17 Mar 06 @ 4:23 pm
thatnks a lot for the info.
geposted Fri 17 Mar 06 @ 9:18 pm
