Hi. I was thinking if it's possible to adapt an automatic play icon in front of each track to make an easy way to access the pre listen, Also instead of commentaries, build a pre-established star row that allows us mark them up using our mouse and giving a favorite value. The same as the music library is shown in otrer programs like Real player, itunes.........
regards
regards
geposted Sun 19 Mar 06 @ 5:15 pm
You can create shortcuts for prelistening tracks directly in the prelisten player.
And also create a shortcut for Edit_commentary so you can add the stars yourself.
Some users use Real comments so i guess you will have to stick witht he actual commentary column.
geposted Mon 20 Mar 06 @ 7:40 pm
Where is the prelistening shortcut? Is not present in the action list of VDJ 3.4 http://www.virtualdj.com/forums/47437/Plugins/List_of_actions_in_VirtualDJ_v3_4.html
This is my idea for new 4.0 version http://img218.imageshack.us/img218/1624/immagine4aj.jpg
But no any modify in the skin, please insert by default in the program.
I think the search bar is too long and near to this a pre-listen button and relative bar is good position, like traktor.
geposted Tue 21 Mar 06 @ 2:05 pm
