Forum: VirtualDJ Skins
Topic: Visual Pannel Source Code possible?
Know anybody the solution of source code for show and hide Pannels with visual action without show the visual on the next pannel when show it or it is not possible? I can`t find the code in the skin sdk too.
example the action visual pannel="40" don`t work
geposted Fri 28 Apr 06 @ 12:52 pm
DJ FORMATPRO InfinityModeratorMember since 2003
You need to ensure you have <up> images set, and ensure the <visual> is set on the pannel you want it on.
If you have diffuculty, I can look into your file and fix this for you...
DJ Format
DJ Mykel
geposted Sun 03 Sep 06 @ 2:37 am
