Does anyone know if it is possible to map a plugin's perameters. What I mean is... I know how to modify/build a skin to place a plugin on/off button anywhere in the skin using the "effect" actions etc but is there a code available to map the settings controls besides just turning it on or off? I use a few of the plugins regularly but I would like to have a more "on the fly" feeling where the perameter controls are always in front of me so I can avoid having to go in and out of the MUSIC / FX windows. I use the M-Audio "Trigger Finger" Midi board as well, is there any way to talk to VDJ plugin perameters through midi?
One good example is the key control plugin. I would like to be able to set the perimeters without changing windows and also have the value always displayed on my VDJ skin.
Peace out,
Funkmasterfrank
Montreal
Peace out,
Funkmasterfrank
Montreal
geposted Tue 02 May 06 @ 6:15 am
In midi , you can control the buttons and the first slider of the plugin.
geposted Wed 03 May 06 @ 10:50 am
