What MP3 Tools Are You Using??
I use mp3 gain, and mixmiester so far so good
geposted Thu 04 May 06 @ 11:55 pm
(Easy CD-DA Extractor 9) (Tag-Rename) (MP3Gain)
(Virtual DJ Professional 3.4) (BPM Studio Professional 4.9) (PCDJ FX Professional 7.3)
geposted Fri 05 May 06 @ 12:14 am
cdex, Mac (Music Audio Catalog), winamp, wmp, Virtualdj, dvd shrink. Some little applications created myself to create playlists, folders with shortcuts, rename files etc.
Ewout
Ewout
geposted Fri 05 May 06 @ 12:29 am
MP3 Tag Studio (does what the name suggests!), PsychicMP3 (for cddb lookup), Media Player (for cd ripping & encoding) and of course VDJ....
geposted Fri 05 May 06 @ 2:02 am
Media Monkey (RECOMMENDED...), mp3trim, DbpowerAmp.
geposted Fri 05 May 06 @ 2:28 am
Anybody know of a program that can scan an entire mp3 library, and weed out any corrupt mp3s? I have too many to check them all by hand, and there's always that niggling doubt in the back of my mind when I load a track I haven't played before... will it crash vdj when it loads? It's never happened yet, although I've crashed pcdj in the past with corrupted tracks.
geposted Fri 05 May 06 @ 4:43 am
Zortam id3 Tag editor (godsend), nero wave editor, audiograbber(ripping), backup dual winamps, ableton live, mixmeister BPM tool, VDJ!
geposted Fri 05 May 06 @ 6:42 am
VDJ (mix), Sony Sound Forge (edit), Sony CD Architect (create), iTunes(manage), Winamp (listen)
VDJ Rulss
VDJ Rulss
geposted Fri 05 May 06 @ 11:29 am
dBpowerAMP to Rip CD into mp3 or make a conversion to any music file to mp3, Tag & rename to edit the tag & winamp to play some long mp3 with the relative cue info file. VDJ can not separate the long mix mp3 with the relative .cue file.
geposted Fri 05 May 06 @ 3:10 pm
