Not everyone visits the Hardware Technical support area so I posted this message to alert someone who has experience configuring it. I need to use it at a gig tonight!
It is titled "Problems configuring X Session"
Peace out,
Funkmasterfrank
Montreal
Peace out,
Funkmasterfrank
Montreal
geposted Fri 05 May 06 @ 6:58 pm
i don't own it, so i can't help you, but you can still use effects as shortcuts at your keyboard! so you can do your gig perfect although you don't use 2 buttons at this controller ;)
geposted Fri 05 May 06 @ 7:09 pm
I don't have them here, but I can email you my settings when I get home at 4:15.
It's easy to set up, just open up keyboard shortcuts click add, move a dial so the program recognises it and then assign it to what you want it to do.
geposted Fri 05 May 06 @ 7:54 pm
Thanks for the info....
I already know how to program the controller. With the exception of the 2nd & 3rd Effect on/off button everything works great. Here are the steps I used:
1) Open keyboard shortcuts tab
2) Click add
3) choose effects in left window
4) choose effect in right window
5) Choose which deck I want to assign
6) Change value to "1" for 1st effect button
7) choose which button on controller I want to use (button 1)
8) Click OK
9) Click OK
10) Works Great for effect #1 on/off on each deck(Did exactly the same proceedure for other deck)
Now I try to do the same for effect button #2
1) through 5) Done...
6) Change value of "effect to "2" for 2nd effect button
7) Choose which button on controller I want to use(button 4)
8) Click OK
9) Click OK
10) Now when I press the corrasponding button on my controller effect #2 turns on and when I press again to turn it off effect #1 turns on along with #2, when I press a 3rd time(#2 effect) #2 shuts off and #1 stays on. Pressing a 4th time turns off #1. The original button #1 that I assigned works properly all the time. effect #1 turns on/off like I'm pressing the real assigned button on the controller(button 1)
Am I choosing the right selection or the wrong value in the right window? My choices are: "effect" "Effect Button" "Effect Select" & Effect Slider. I assume it's "effect" and then choose value. I tried every other choice and nothing worked.
Peace out,
Funkmasterfrank,
Montreal
2) Click add
8) Click OK
9) Click OK
8) Click OK
9) Click OK
Peace out,
Funkmasterfrank,
Montreal
geposted Fri 05 May 06 @ 8:30 pm
Thanks for eveyones help...
I found the problem. The x-s had to be reconfigured as it already has presets in it for other progs that come with it(lite versions). I just had to redefine the buttons using the software that is supplied with it(enigma). It now works great with VDJ. Very clean crossfader feel. I was configuring VDJ properly from the get go.
Peace out,
Funkmasterfrank
Montreal
Peace out,
Funkmasterfrank
Montreal
geposted Sun 07 May 06 @ 12:06 am
Funkmaster, what exactly did you do to it, is there a help file??? I too am using the X-Session along with the MK2.
geposted Mon 08 May 06 @ 4:29 am
