Forum: old old beta forum
Topic: beta 18
We're getting close from the release.
Not much left in the todo list :)
beta18
- record fixed
- effect tooltip kept upon skin change
- SendCommand function in effect SDK works.
- beatlock display when skin changed fixed
- autosync option removed (was meaningless)
- ctrl-a in list selects all songs
- new joystick behavior in djconsole
- new font for author/title
- effect engine fixed
- new effect: reverse
- broadcast fixed
- rightclick on slider's fader bug fixed
- songpos on light skin fixed
- texts on light skin fixed
- sample volumes saved
- language us.xml updated
geposted Fri 23 May 03 @ 5:05 am
I've updated the language.xml with all the new strings.
Actually all the four language are the same file (in english), so if someone can make the translations in french, spanish, german, and verify the english...
You can inspire from the old atomixmp3 language file, but beware that most of the xml tags are not the same, even if the sentences are...
Thanks,
Stef.
All this time I never put VDJ in simple mode man I completely missed that!
GREAT ! ! !
The reserve effect is ready ! ! Yeah ! ! ! ! !
don't forget cue 1 like Atomix please :)
Cue 1 is the most when your mixing fast !
I will translate the french version.
I´ll do the spanish :))
Could you create a guide for the reverse effect to "reverse faster" ?
To simulate the fast reverse of a vinyl...
Could you send me the translated xml on my email when it's ready please.
About the Cue1, Due to the way vdj load a track, I prefere to let it load from the beginning to the end in most case, that's why you still have to hit stop to rewind to cue1 at load time.
About the effect, I will make changes (and new ones) after the release.
Now I just want to make sure that almost everything is doable with the effect engine (and easy), that's why I made this reverse plugin.
Sent it ! =)
I help Coco for the Spanish.
Coco, can you send it to me by e.mail
Thanx
