Is there any way to highlight a folder and autoplay the songs in that folder without dragging the songs to the playlist or making a playlist first?
geposted Sun 04 Jun 06 @ 7:33 am
You can drag that folder to the waitlist and open it up in there and it will autoplay from there. I wondered the same thing as I have some of my music organized in folders that are like waitlists. Hope that helps. Cheers Brian
geposted Sun 04 Jun 06 @ 9:34 am
Thanks, did not know I could do that
geposted Sun 04 Jun 06 @ 8:30 pm
version 3.4 will not allow me to drag an entire folder to the playlist. I did not try to make it a "Favorite" first. Next idea please!
geposted Mon 05 Jun 06 @ 9:22 am
I was saying that you can save each folder as a playlist, then simply drag that folder over and mix. You have to save it then click on PLAYLIST to see those folders you just created. Cheers Brian
geposted Mon 05 Jun 06 @ 7:53 pm
