I've just recently started having this problem -- VDJ isn't saving the database correctly, at least with comments... I have been putting in comments, but then when I exit VDJ, and later restart it, the comments I made are not there. If I add them again, and exit, then they stick. But they don't save the first time. Any idea why this is happening? How to stop it from happening in the future? Thanks!
geposted Tue 13 Jun 06 @ 3:23 am
I suggest you check your shortcuts for save database and do that before you shut down the software. I don't know what the default is off hand, but it seems to work great. Cheers Brian
geposted Fri 16 Jun 06 @ 9:36 pm
