The music files should be able to flow. for exmaple if I bring a track to the tables from the Playlist (which should also display the bpm, by the way) and decide to use a different song, I have to go and search for that track again and add it to the playlist. rather then just dragging it back to the playlist window.
geposted Wed 21 Jun 06 @ 2:37 am
Are you talking about UNLOAD function? Don't really know if it is included into 3.4, but it sure be in 4.0 :)
geposted Wed 21 Jun 06 @ 11:04 am
It's not possible now, when you drag a song from playlist you lose the track in the list and you can't dragging it back.
If you buy the full version you can pre-listen the track before the draging into the deck.
geposted Wed 21 Jun 06 @ 11:21 am
You can also use the side list, OR use the option "repeat playlist" which will put the played track back in the playlist section.
Anyway this problem will be solved in version 4. Wait and see ;)
geposted Wed 21 Jun 06 @ 11:33 am
