Topic: AMD Athlon Vs P4 3Ghz
Gday
im looking into buying a second computer for virtual dj and m just wondering what would run virtul dj better.
number one is the AMD Athlon 3200:
AMD Athlon 3200 + 939 Processor
1 Gig DDR ram
Nvidia Gforce 610 video / 6 chanel audio
200 Gig HD
number 2 is the Penium 4 3.06Ghz
P4 -3Ghz 775 Processor
1 Gig DDR Ram
Sis mirage video / 6 chanel audio
160 Gig HD
thankyou.
geposted Sat 24 Jun 06 @ 6:40 am
Ohm_RSAPRO InfinityMember since 2006
Both boxes look pretty strong, I can't give you advice on VDJ but from a PC perspective those both look like onboard video, I'd recommend an AGP or PCIX video card with it's own memory for multimedia intense applications.
geposted Sat 24 Jun 06 @ 7:53 am
Cheers for the quick responce, can anybody give me a more in depth comparrison, much appreciated.
-Stevo
geposted Sat 24 Jun 06 @ 8:21 am
JeremKPRO InfinityModeratorMember since 2004
geposted Sat 24 Jun 06 @ 12:05 pm
geposted Sat 24 Jun 06 @ 12:28 pm
phillydjPRO InfinityModeratorMember since 2004
Hmm 64bit vs regular P4 no real comparison there go with the AMD i think u might have failed to mention that socket 939 is 64bit :)
geposted Sat 24 Jun 06 @ 4:34 pm
The p4 he is picking is skt 775 which it makes it a prescott, the 500 series with 1's with the last digit have em64t (ie 521,531 etc...) All of the 600 series have EM64t which makes them 64bit :P If he chooses a P4 with a sky 975 chipset R3 he will beable to easily upgrade also to Conroe ;) at 2.6ghz it ourperfoms an AMD fx62 at 3.0ghz, buying a 64bit proc has no baring unless you intend to use a 64bit host operating system :P (i.e. when vista comes along). Id use a opteron if im honest or id w8 for the intel core chips (conroe). But out of them two i think the AMD just edge's it for perfomace so go with the AMD ;)
geposted Sun 25 Jun 06 @ 7:50 am
I have an Athlon 64 X2 4800. Maybe its a little over-kill and expensive still at $630US. But with VDJ it runs about 3%-6% CPU usage. So basically thats with one hand tied behind its back because its a dual core prox which means one of those cores is working at about 6%-12%. What this all means is that you can Rip or burn a CD or DVD while playing songs or videos in VDJ. Just to put it to the test I Riped a dvd while mixing several videos and the CPU usage got up to about 53%. There was no stuttering or adverse effect on the sound or video. In conclusion, I'm extremely satisfied and would have spent the money again!
AbsoluteDJ
In case you were wondering:
Athlon 64 X2 4800
Asus A8N-VM CSM
6600GT 256
2GB Ram
3 x 500 GB SATA2 HDs
Plextor 18x +/-R 10x DL CD/DVD
Waveterminal
And the kewlest (lightest) HTPC Case Ever:
NMediaPC 200BA
geposted Mon 26 Jun 06 @ 9:44 am
apopsisdjPRO InfinitySenior staffMember since 2003
go amd, best value for money+performance
geposted Mon 26 Jun 06 @ 3:31 pm
AMD is the best! Many comparisons of equally-priced Intel vs. AMD chips show AMD comes out on top again and again. My system never has any problem whatsoever keeping up with:
AMD Athlon 64 x2 4400+
Asus A8N-SLI Premium
2 gigs Corsair ram
geposted Mon 26 Jun 06 @ 4:26 pm
Love to see so many VDj users love AMD :) I guess we know who the winner is. Like VDj AMD packs the best bang for the buck clearly
geposted Mon 26 Jun 06 @ 5:59 pm
