Topic: Having problems in the Video Dept. - Page: 2
Well after further playing around with this I have noticed that the video effect plugins do not work either.
The list is their in the visual plugin dropdown list but everything is black. I got this to work on the Dell also. I really need to get this HP up and running because overall it performs better than the Dell.
geposted Wed 12 Jul 06 @ 3:52 am
Anybody, I've hunted these boards and can't find an answer.
geposted Wed 12 Jul 06 @ 3:30 pm
frd1963PRO InfinityMember since 2004
Do karaokes and visual plugins work when you output VDJ video to a window on your main screen?
geposted Wed 12 Jul 06 @ 3:50 pm
phillydjPRO InfinityModeratorMember since 2004
hate to say it but why not just to a clean install of everything OS and VDJ or you can try just a clean install of VDj if you do remember to delete any case of it from your registry. @frd963 yes karaoke and visual plugins should
geposted Wed 12 Jul 06 @ 4:35 pm
I will try a clean install of VDJ when I get back in front of that machine.
geposted Wed 12 Jul 06 @ 5:43 pm
thats probably the best thing to do ....beside it's always good to clean install everything....if u clean install xp remember to tweak it when ur done
geposted Wed 12 Jul 06 @ 7:29 pm
Well I tried a clean install of VDJ and I still get the same thing.
geposted Wed 12 Jul 06 @ 11:41 pm
wow sorry to hear that....it has to have something to do with ur display drivers ..you get nothing at all? is this all of the karaoke did u try disabling hardware acceleration
geposted Wed 12 Jul 06 @ 11:45 pm
I'll be darned. I turned off hardware acceleration and all's well. I thought I attempted this already, but I guess I didn't. Thanks for all your help, Phillydj. It seems its always the little things that are looked over.
geposted Thu 13 Jul 06 @ 3:25 am
thats ok ...some laptops don't support that feature very well....hence the reason i choose a 1u server..but im glad it's all going well for you now. anytime u need help you know where to look
geposted Thu 13 Jul 06 @ 9:06 am
