do you any one can help me with this? how will make my hercules jog weels control everytime i want an effect like the wah,zip andjet (pioneer cdj100) ??
i will buy soon the pro version (almost did but some techinical problems stop the activation) and i want to know that...i find it most important of everythink....
with jog weels if you mix... you can use the jet effect to go to an ather song more easy,.... and so many ather uses of them
geposted Wed 19 Jul 06 @ 7:50 am
At the moment you can't use djcel's mapper, as you can't with the Home Edition.
geposted Wed 19 Jul 06 @ 11:32 am
yes i know that... i cant download it
but i have to know if i can do that when i upgrade to pro... if djcel mapper is the right tool for that i want to do
geposted Wed 19 Jul 06 @ 1:26 pm
Yes i have addes this function: you can control the effects slider with the jogwheel (but it's a finite "rotation" as a slider is limited to min and max)
geposted Wed 19 Jul 06 @ 10:07 pm
Cel, I didn't realize that was possible. I am going to have to try it. Unfortunately, I normally use the jogwheels as jogwheels, but I do have another Hercules (MK I ) with the button problem. Is it possible to attach the second Hercules and map its functions independently of my MK II? Or would I have to use it as a regular MIDI device and map it that way?
geposted Thu 20 Jul 06 @ 7:36 pm
it is dificult for atomix make a version of virtual dj tha acts like the decks...
use the jog weels normaly but when u chose an effect dont work the same time.. only when u start use the jog weels...
i think that should not be so hard to make it truth
geposted Fri 21 Jul 06 @ 12:03 am
There are hidden options in the default mapper of Atomix Productions too ;-)
Keep the button "mode selection" pressed and move the jogwheel at the same time. There is one thing in loop mode and another one in effect mode
geposted Sat 22 Jul 06 @ 2:39 pm
realy? this is very intersting.. i hope work with my home version... ;)
thank djcel.. i hope still working in the vdj project and bring to as more and more useful things...
maybe try make work a cdj 100 pioneer skin like a real pioneer :)
and agian thank sharing this information
geposted Sun 23 Jul 06 @ 1:04 am
djcel i open my program go to remote control.. and in hercules i cant find any bitton for mapper...
how can i start mapper?
geposted Sun 06 Aug 06 @ 2:39 pm
geposted Mon 07 Aug 06 @ 6:00 pm
ok..everything is ok now :) something was wrong but now works... :)
geposted Mon 07 Aug 06 @ 7:38 pm
great
what was the problem?
geposted Mon 07 Aug 06 @ 7:40 pm
