Topic: How to record?
djcityPRO InfinityMember since 2005
I want to record my mixes onto c.d. I have hit the record c.d. button but it does not record my mix.
How do I record???
geposted Tue 25 Jul 06 @ 3:56 pm
xeonPRO InfinityModeratorMember since 2004
When you set to record to cd it record your mix to .bin and .cue files which you have to record to cd using burning software.
geposted Tue 25 Jul 06 @ 4:27 pm
What the heck is a .bin and .cue file?
Where are these files located on the computer?
After finding these files...Then what?
Why can't VDJ burn directly to a cd?
geposted Tue 25 Jul 06 @ 6:48 pm
VDJ doesn't have recorder built in. You have to open them using nero for example and burn them to cd (but not as data cd, you have to open them with burning software).
geposted Tue 25 Jul 06 @ 7:10 pm
erxonPRO InfinityMember since 2003
Google is your friend.
geposted Tue 25 Jul 06 @ 8:24 pm
