I have put in A LOT of work getting all my bpm's correct, getting the beatgrid correct, and setting cue points.
When I have my external hard drive hooked up to my laptop, all the info is there. I did all the work on my laptop.
But when I hook the same external hard drive up to another computer with VDJ, all my info is gone. It does not transfer to the other computer.
Why is that and how do I correct this... I use virtual DJ and my hard drive on my laptop most of the time, but I sometimes use VDJ and my hard drive on my desktop computer or I use my hard drive on a friends computer with his VDJ.
I would like to have ALL my info EVERYTIME I use my hard drive, weather it be on my laptop, my desktop, or a friends computer who has Virtual DJ.
geposted Wed 02 Aug 06 @ 6:50 pm
This info is in the file called "VirtualDJ Database.xml" which is in the top level VirtualDJ folder (i.e. "C:\Program Files\VirtualDJ")
You would have to copy this file over to other computers for all of that info to be copied.
It can be automated using batch scripts, etc.
geposted Wed 02 Aug 06 @ 7:07 pm
when u copy your database , make sure u move his to a safe location otherwise you'll overwrite it , after your done your set put his database back , or you can merge the 2
geposted Wed 02 Aug 06 @ 7:20 pm
What is a batch script and how do you use it? I like the automated idea.
geposted Wed 02 Aug 06 @ 7:44 pm
A batch script is a plain text file with a ".bat" extension. It contains commands just like those that could be run in a DOS window, like "copy", "move", "cd", "mkdir", calling other batch scripts, or even launching VirtualDJ. When you 'call' the batch script, it runs through the list of commands one at a time until the end.
You can have an "autorun.inf" in the root directory of the device that calls the ".bat" script so that its commands get run whenever you plug in that device.
If you decide to do this, let us see what you come up with.
If you need assistance, let me know.
See my blog for an example of a batch script for making backups of VDJ machine specific info.
geposted Thu 03 Aug 06 @ 4:22 pm
