Resizeable skins
Or better support for more resolutions. If it is possible there should be at least the following resolutions with each skin.
800x600
1024x768
1280x720 (Widescreen)
1440x900 (Widescreen)
1600x1200
1920x1080 (Widescreen)
800x600
1024x768
1600x1200
geposted Mon 14 Aug 06 @ 6:45 am
I totally support this, but it would require a completely different skinning technique from what's in place now.
geposted Mon 14 Aug 06 @ 10:11 am
Since I've designed skins, I'm pretty knowledgeable about how they work. I would think that it should be pretty trivial to make virtual DJ so that the height could be moved within a certain range... as for changing the width, that could be quite a bit more difficult.
If they could change it so that the height could be changed though, that would be awesome. I suppose you could make a tile for the background for the browser section or something, and it could repeat... then you could use the exact same skin at 1280x768, 1280x800, 1280x900, 1280x1024, etc. without having to actually change the graphic, move everything down, and change hundreds of lines in an XML file (which I have a script to do, but it's a pain still).
geposted Mon 14 Aug 06 @ 7:32 pm
That's my thinking as well, Supacon.
geposted Tue 15 Aug 06 @ 10:45 pm
