hey...
I am new to virtuel dj, and i am using version 3.1...
I dot NOT mix songs, but use it to play the songs in a playlist one after one, and auto dj is enable...
but in some songs where there is low sound in the beginning vituel jump over the low sound and starts in the 15-20 second...
how can I change that function??
Grohnheit
Grohnheit
geposted Wed 16 Aug 06 @ 4:05 pm
Why do you use a cracked version ?
geposted Wed 16 Aug 06 @ 4:12 pm
because I use the program 3-4 times at 1 year...
and I dont want to pay, if it dosnt work good...
geposted Wed 16 Aug 06 @ 4:18 pm
It works perfectly, and guess what..., i know the answer for what you ask.
It's just a user preference and not a software fault in any case...
Support the program, or just keep "low" profile if you don't.
geposted Wed 16 Aug 06 @ 4:27 pm
The program does work perfectly, usually cracked versions are bundled with all sorts of malware and adware so be aware of that even if you using it 3 to 4 times a year
geposted Wed 16 Aug 06 @ 5:47 pm
yes, the problems you have are because of that cracked version that should be full of bugs, buy the pro version and your problems will go.
geposted Wed 16 Aug 06 @ 6:45 pm
grohnheit wrote :
I dont want to pay
geposted Wed 16 Aug 06 @ 7:36 pm
Hey; I don't want to pay either. Can I get a refunf?? (LOL)
program is great and works as long as you have a legitimate one.,
geposted Wed 16 Aug 06 @ 8:53 pm
@grohnheit
a totally friendly advice.... If you ONLY use VDJ 3-4 times a year, and its ONLY for automix.. VDJ is really not your program. Get iTunes... Its free, and have auto-mix with "crossfading" function.
And save up for VDJ if you are going to mix yourself in the future, or use the program more than once every 3rd month... ;)
geposted Wed 16 Aug 06 @ 8:59 pm
In that case you could also use Winamp with the crossfader plugin, also free.
Ewout
Ewout
geposted Wed 16 Aug 06 @ 11:04 pm
I stole a Mercedes SLK last week. Was having some problems with it though, so I took it back to the garage I stole it from and asked if they could fix it for me. Can you believe they took the car off me, and now I'm going to court?!?!
geposted Thu 17 Aug 06 @ 2:06 am
^^ LOL Good one!
geposted Thu 17 Aug 06 @ 4:16 am
^^ :-O, NO WAY.. are you serious, ya know what, people these days, have no respect for the average Mercedees thiefs like yourself. I feel for you :-(
geposted Thu 17 Aug 06 @ 5:26 am
I would have stolen a Mercedes SLR :-p
geposted Thu 17 Aug 06 @ 10:57 am
I just stole a mercedes SLR, but it is ok, while I use it only 3 or 4 times a year ;-)
Ewout
Ewout
geposted Thu 17 Aug 06 @ 7:08 pm
The guys got balls. But like most thieves, they are bigger than his brains. What happened to the good old days, when thieves kept their mouths shut. No respect for the profession.
geposted Thu 17 Aug 06 @ 8:26 pm
If I were stealing a car it would have been some as cool and sleek and hot as VDJ. Mercedes are cool but I would compare VDJ to say a Lambourghini ( not sure how to spell because I don't think I will be needed to shop for one). But if I did, guess I would want to show it off more than maybe 3 or 4 times a year.
Dude the software works, hell they give you a free trial version just to prove it works and you get great support right here on this forum, not just a pile of BS like right now. You really insult the people who do pay for it and then come on here asking for help. It just costs us more $ when someone tries to go around the system. It just doesn't work.
Ok I'll climb off of my soap box now, can some one get me a ladder?
geposted Fri 18 Aug 06 @ 3:51 am
Can somebody lend me there girlfriend, I'll only use her 3 to 4 times a year
geposted Fri 18 Aug 06 @ 5:58 am
^^ For what? :))
geposted Fri 18 Aug 06 @ 6:35 am
geposted Fri 18 Aug 06 @ 7:18 am
