Forum: old old beta forum
Topic: beta 19
beta19
- simple skin fixed
- bug in the language fixed
- %tocueX, %fromcueX, %tostart, %fromstart, %toend and %fromend value added in (skin)
- fader temporary bug fixed
- remote debugging (fatal error reported in crashrecover is now useful to me)
- pitch reseted to 100% on load of an unknown song
- songpos intensity on new song loaded fixed
- save edited shortcuts from vdj in the xml
- new action: skip_beat
geposted Sun 25 May 03 @ 6:35 am
Ok now all that is left to do is to get rid of all the crashes.
From this version, the numbers given in the recover message are meaningful, so please report them (and the thread name also) as soon as you have a crash.
Please try also to make all the crashes you already reported happen again, because if I haven't corrected them yet, it's because I don't know where it comes from and I need those numbers to find.
Stef,
I was unable to hear the pops and clicks last night but I could only run VDJ for a short time as people began to come in. I will try it again today probably and let you know. It seems like it doesn't happen immediately though it happens after time.
Stef could you add to beta 20 a right-click option in the effects ? On the skin, a right-click on an effect activates the effect while the mouse button is pressed, but in the effects panel, the right-click does the same thing as the left-click.
Im hearing those pops like homeboy said ( in mayority of the songs each 2 beats)...
Sounds like an old vinyl..
Yes but starting from which version?
I agree it does sound like old vinyl. It is in version 18 and 19. I didn't hear it before this. I will do some serious testing at home tonight. I will be using headphones so its tough to know if I will hear them or not. In a bar enviroment it is obvious.
Does it happen in one soundcard mode only, or in any mode?
I noticed it in 1 soundcard mixer set up. I will try the others soon;)
I have tried all and I am pretty sure it is throughout each setting. It is very difficult to tell with headphones. :( Try loading a song that is quiet in the begining it is more noticable then......Also Stef I see that you said that the bpm will be automaically adjusted only if and when vdj scans it. I have manually tapped out some tracks and vdj is not adjusting the bpm to match automatically.
I wrote it in another topic where you asked, but i´m hearing these pops since b18. and i am using 3D with headphones.. I´ll try another config tonight...
