Can I have v 3.x and v4.x installed on my system at the same time to do some testing with v4.x before I play out with it in front of people ???
I want to be able to use v3.4 until I have time to test v4.x and make sure it's stable :)
geposted Mon 21 Aug 06 @ 8:03 pm
Should work. Just install it under VirtualDJ4 folder or something similar :)
geposted Mon 21 Aug 06 @ 8:21 pm
just rename the virtualdj.exe to virtualdj_34.exe, before the install of VDJ4.
And you can run both version ;)
geposted Mon 21 Aug 06 @ 9:00 pm
either of the 2 ways mentioned above will work, just make sure u back your database up
geposted Mon 21 Aug 06 @ 9:26 pm
Wouldn't you need a full install to have both? Usually there is just an upgrade.
geposted Mon 21 Aug 06 @ 9:38 pm
More than likely it will be a full install if it isn't do as Norway said earlier rename the old vdj. exe to something else
geposted Mon 21 Aug 06 @ 11:17 pm
It will be a full installation file I'm pretty sure.
geposted Tue 22 Aug 06 @ 12:06 am
