How do you add effects if you just have 4.0 installed and you did not have 3.4. I had to do a system restore and then just installed 4.0. When I try to install an effect I get the error "no software found". I know how to do the effects from 3.4 but problems with just 4.0
Chris
Chris
geposted Tue 29 Aug 06 @ 4:02 am
It will be fixed. The old plugins are compiled for 3.4, and looks for 3.4 install
geposted Tue 29 Aug 06 @ 8:26 am
Some plugins are already updated (when it's written "it only works for VirtualDj v4.x and Numark Cue"), the other ones wil come little by little
geposted Tue 29 Aug 06 @ 1:18 pm
