Forum: VirtualDJ Skins
Topic: multiple function per button
I'm sorry if this has been answered before, but I couldn't find it...
As far as keyboard shortcuts are concerned, it is possible to have a single key perform as many actions as you like. (for example: skip back 16 beats + start 16 beat loop)
Is it possible to program the buttons in a skin to do more than one thing?
Thanks,
Steve
geposted Thu 31 Aug 06 @ 7:28 pm
Unfortunately this isn't possible yet.
*sigh* ok thanks. I guess I'll fine some other way to do what I want or just use more keyboard shortcuts.
Maybe in the future...
I'll share a tip that I use. I have a Belkin n52 pad which is programmable. That is where i setup all my key combos and has worked pretty well for me. You can use other programmable input devices too.
Mx
So it's not possible... shame.
I am currently making a skin, and I thought of making a "master" channel for effects, which would basically be knobs with same functions for both decks simultaneously - well I guess it won't work.
I really think this would be a useful feature for those who do use skins' knobs & sliders.
