Well I am having problems with my system sharing IRQ's with Windows XP Media Center Edition. Will adding Windows 2000 Professional to the system support PCI E X16 Graphics cards??? The problem is that everything I add keeps going to the same IRQ of 16 and there is no way to change it, or is there??? There is nothing in the BIOS, and in Device Manager the Boxes for automatic are all greyed out and can't be changed. Thanks
geposted Fri 08 Sep 06 @ 8:11 am
XP Pro, and Media centre should support the same devices, Pro, maybe more. If windows does not support it directly maybe the manufacturer should anyway.
In windows you can "Change" the irqs, but I find its just cosmetic and changes it on the screen while underneath windows leaves the IRQ the same. I have found the best way to change IRQ's is to physically move the cards around from slot to slot, as each slot is assigned a IRQ.
geposted Fri 08 Sep 06 @ 9:37 am
Windows 2000 isn't a good choice here. Better maybe Windows XP Pro or home ed or Media Center.
IRQs can be changed in the Windows Device Manager. Right Click on My PC icon and select Propeties->Hardware->Device Manager
Goood Luck!
Goood Luck!
geposted Fri 08 Sep 06 @ 10:01 am
I have winxp home and everything works :)
geposted Fri 08 Sep 06 @ 11:25 am
