Guys take a look at this.... it's a 50" touchscreen and a dj software from pioneer...
it's on norwegian.. maybe you can translate it with babelfish or something...
http://www.dingz.no/php/art.php?id=318014
and check out the video at the page... :D
geposted Tue 12 Sep 06 @ 4:18 pm
It is possible to do like this with VDJ and touch sensitive screen. You can even scratch ;)
geposted Tue 12 Sep 06 @ 4:37 pm
cool...
geposted Tue 12 Sep 06 @ 4:50 pm
Scratching will become quite hard, while only the touch screen latency is about 20-30 ms. Then you have to add the dj software latency, os latency and soundcard latency. I have a touch screen and tried it once. It is simply too slow.
Ewout
Ewout
geposted Tue 12 Sep 06 @ 8:16 pm
But do you use the touchscreen to control VDJ?? And does it work for the basic controls??
geposted Tue 12 Sep 06 @ 8:25 pm
I tried it for the basic controls. You can't use the normal skins, while the buttons are too small. You have to create a special touch screen skin. I did that. It worked quite well, especially for a normal "wedding" gig without mixing. Mixing becomes a little harder, scratching is simply too hard.
Im not using this touch screen for VDJ. I use it with Sunlite to control the lightshow.
Ewout
Ewout
geposted Tue 12 Sep 06 @ 8:38 pm
Looks just like a display set up at a trade show. We did the same thing only we used 10 plasmas instead of one. Take a look
geposted Tue 12 Sep 06 @ 8:55 pm
pretty cool....
isn't it any fast touch-screen monitor out there..?
geposted Thu 14 Sep 06 @ 4:46 pm
That software sucks, surprized pioneer even put their name on it.
geposted Thu 14 Sep 06 @ 5:19 pm
lol :D
geposted Thu 14 Sep 06 @ 7:05 pm
well... I don't like the skin they are using... but I don't know anything about the software...
geposted Fri 15 Sep 06 @ 3:02 pm
Ever look into the Lemur?
http://www.jazzmutant.com/lemur_overview.php
Dedicated touchscreen device that can track multiple touchpoints at once (regular touchscreens can't)
Costs way to much for me to consider, but would be very nice to have.
geposted Fri 15 Sep 06 @ 4:27 pm
I took my daughter to the zoo the other day, and thats what they had 50" plasmas with touchscreen kits
nededless to say I wanted to take one home , but I didnt wear a big enough jacket :(
geposted Fri 15 Sep 06 @ 6:44 pm
hehehe..
geposted Tue 19 Sep 06 @ 8:54 pm
