Just an idea....is there or could some bright spark write a plugin that allows you to have adjustable echo on your mic - this would be a godsend for us KJ's
It would be awesome if this could be done automatically with the DJ Console.
Just an idea....would it be possible?
geposted Thu 08 Jul 04 @ 7:12 am
A lot of people suggested to have a separate plugin row only for mic, for example (I suggested it already too): http://www.virtualdj.com/forum/display.html?topic=5487.
Possibility to use one or more plugins only for mic would be very interesting, not especially for KJs but also for other DJs.
Clax
Clax
geposted Thu 08 Jul 04 @ 9:35 am
The point is that we have to record the microphone input to to this.
We also have to put this data back to VirtualDj in plug_ins... but if there is no sound playing, the effect will not send this data back.
So it is not really interesting to use it as plug_in.
The best solution is to use other little software that are able to do this out of VirtualDj.
geposted Thu 08 Jul 04 @ 12:52 pm
In a similar vein, why is my laptop only playing the audio part of genuine CDG's?
It plays MP3+G's okay but real karaoke disks are coming up only as audio and it's not showing the words....my drive is capable of reading CDG's (Plextor 708a DVDRW) so surely it should work?
If the plugin cannot do this then us KJ's in the UK cannot use the karaoke plugin legally as we have to use original Karaoke disks (our law here is silly in the fact that even though I own a bundle of genuine karaoke disks I am not allowed to make a single backup of them even for personal use)
This has to be sorted as I wish to use the program in pubs etc. and it will be the same for all UK KJ's - Any ideas?
geposted Thu 08 Jul 04 @ 3:14 pm
music and sound file must be in same folder...
then i works fine
then i works fine
geposted Fri 09 Jul 04 @ 1:47 pm
ThankXxxxxxs
geposted Wed 10 May 06 @ 3:29 pm
A method could be to insert the mic into the default soundcard (if there's one we aren't using), then apply filters on it, and send the output into the line input of the other soundcard. This is the simplesy way. It works ;)
geposted Thu 11 May 06 @ 10:12 am
this is a great software but a bit costly the sound effects provided are great.hope for further modifications
geposted Sun 21 May 06 @ 1:19 pm
hello everybady im from Poland and i can write
geposted Mon 29 May 06 @ 8:44 pm
