is it just me or does the beat matching not work as good on 4.0?? i'm tempted to go back to the 3.x for this reason.. it seemed like it matched much better.. d-.-b
geposted Fri 15 Sep 06 @ 1:10 pm
what exactly is the problem your having with it?
geposted Fri 15 Sep 06 @ 1:15 pm
Why don't you adjust the song speed by hand? It's so simple!
Anyway, it's the same algorythm, maybe the shortcut you're using isn't the one do do the "old-style" beatmatching, but just a synchronisation... Check that!
geposted Fri 15 Sep 06 @ 8:08 pm
Ensure that in your CONFIG->OPTIONS...AutoBPM=ENABLED
geposted Fri 15 Sep 06 @ 8:23 pm
