is there an effect out there that works with the video. like if i hit the echoo effect will the video freeze frame or do i have to buy some othe effect gen to make something like that happen.also why when i try to download certain skins, effect, etc i get the statement, you need virtual dj install first when it already installed
geposted Tue 03 Oct 06 @ 12:28 pm
Verify the compatibility with the version that you use
geposted Tue 03 Oct 06 @ 4:48 pm
yo i dont get what you are saying cel
geposted Tue 03 Oct 06 @ 6:05 pm
Some of the effects are only for version 4, others are only for 3.4. Please read the comments at each effect and check if it is for the version you use. You could also try downloading again: The folders in VDJ are changed, so probably the installation files downloaded long ago, will not work anymore.
Ewout
Ewout
geposted Tue 03 Oct 06 @ 6:40 pm
now when i download the effect will the work with the video as i stated above
geposted Tue 03 Oct 06 @ 10:21 pm
