Hey All, love 4.0. My video dance parties are cool. I downloaded some of the video plug ins but they do not work. I keep getting the message - "application failed to start because d3dx9_30.dll was not found. Re-installing the application may fix this problem." Can anyone help out. Thanks
geposted Tue 03 Oct 06 @ 10:39 pm
you may need to have direct x installed if you are going to use hardware acceleration, make sure you have the latest direct x installed and have a vid card with direct x compatibility
geposted Tue 03 Oct 06 @ 11:01 pm
Yes you need to update your DirectX.
It was written in commentary ;-)
geposted Wed 04 Oct 06 @ 12:12 am
Get it here:
http://www.softwarepatch.com/windows/directx.html
geposted Wed 04 Oct 06 @ 8:30 am
