Forum: Old versions
Topic: load error
Alright, a brief explanation.
I have all my video currently loaded on an external USB drive. I had been using it to test VDJ. I recently decided to reassign the drive from G to V (for video), and VDJ no longer recognized the tracks in it's database. I can understand this, so no problem there. I am all to familiar with another program that allows me to re link tracks and database information to the tracks if they have moved. I have not been able to locate such an option here. I have also not been able to determine how to batch remove all the broken linked tracks from the databse without starting over completely. Am I missing something there?
Anyhow, this leads to the problem I'm leading into here. When tracks with broken links move into a deck, it shows an error, and just plain stops when reached in automode. Why is it that when an error occurs like this, it doesn't just move on to the next track? Personally, I find this odd, but then I'm used to my other software reacting as I explain..... Bad track? Pass, NEXT!
geposted Thu 12 Oct 06 @ 2:51 pm
djcelPRO InfinityModeratorMember since 2004
You have to modify the links in this file: mp3database.txt
geposted Fri 13 Oct 06 @ 1:18 am
By Hand? Man, that reaks.... ;)
My other software, I had to tell it to relink by pushing a button, and it automatically took care of the entire database.
Thanks for the tip though! A simple search and replace should work in notepad...
geposted Fri 13 Oct 06 @ 9:59 pm
