Forum: Old versions
Topic: HDC MK1, VDJ4.1rev2, + Mapper
HaywardPRO InfinityMember since 2005
Anyone else having a problem with these?
My computer (dell inspiron 9300, 2gb ram, 80gb hd, ext hd) reacts very slow when the mapper is initiated from the remote tab in VDJ. The CPU usage is at 99% and loading a song onto the decks takes forever.
When I revert back to VDJ4 and the old mappers (HDC + Dac2) everything works fine.
geposted Wed 18 Oct 06 @ 3:41 pm
sbangsPRO InfinityMember since 2004
try lowering proformance tab to fast
geposted Wed 18 Oct 06 @ 4:46 pm
I will try later and update this thread, thanks SKYFXL.
geposted Wed 18 Oct 06 @ 4:52 pm
djcelPRO InfinityModeratorMember since 2004
Yes, i was afraid by this bug
Sorry indeed there is a problem when you enable/disable the djc a lot of times in the VirtualDJ config
I'm still looking for a solution but i wanted to release the DJC mapper anyway to decrease the pressure from users on my back
geposted Wed 18 Oct 06 @ 8:02 pm
OK thats fine at least I can revert to 4.0 until fixed because I am still waiting for Perns mapper for the DAC2.
Thanks.
geposted Wed 18 Oct 06 @ 9:50 pm
