I have been reading arround various post and i can't find direct answer
In Addition to the ICDX Feature is it a direct replacement for an XP-10?
meaning:
Soundcard,
Controller: Access to software FX, looping, and Samples
Thanks,
meaning:
Soundcard,
Thanks,
geposted Fri 20 Oct 06 @ 8:58 pm
Basically it will work in the same sense as an xp10 except that it has a cd/dvd drive you can play discs from and also it doesnt have a built in soundcard.
geposted Fri 20 Oct 06 @ 9:01 pm
also, i don't see anything where I can map the buttons
geposted Fri 20 Oct 06 @ 9:02 pm
So the outputs on the Back are for it's internal CD Player only.
geposted Fri 20 Oct 06 @ 9:14 pm
that's correct.
Maybe there will be maper soon. Or maybe all buttons has defoult functions.
geposted Fri 20 Oct 06 @ 9:28 pm
No mapper yet, but i'm sure there will be one very soon if needed.
geposted Sun 22 Oct 06 @ 10:06 pm
