i know that the problem is not in yje plugin but I ise the plugin alot in 3.4 and it worked with out a problem but with the new upgrade when I click it on and the volume is not and the max(channel volume) the plugin takes it to the max instead of starting from the volume point can this be fixed? is it the plugin or the software?
geposted Mon 23 Oct 06 @ 6:38 am
It's the plugin and yes it can be now fixed by its author
geposted Tue 24 Oct 06 @ 2:05 pm
Please post this in the Plug-in forum.
geposted Tue 24 Oct 06 @ 2:17 pm
