My previous plugin using FFT does not work with V4.x (try Isolator for example)
I am interested to know how I can fix these problems. In my opinion, it is possible because TK filter V2 works with V4.x.
Did someone update Tk filter for V4 or not ?
geposted Mon 23 Oct 06 @ 2:00 pm
Actually, your Isolator plug-in works with v4.x. Unless you're talking about some version that you haven't released.
geposted Mon 23 Oct 06 @ 4:54 pm
It doesn't work if you change the parameters when the plug is actived.
geposted Mon 23 Oct 06 @ 5:05 pm
@Deun-Deun
It perfectly works for me.
Just the sliders are initilialy changed but it's the v4 system
geposted Mon 23 Oct 06 @ 5:24 pm
Which onoes? I believe all paramaters respond accordingly on my system.
geposted Mon 23 Oct 06 @ 6:08 pm
Hi Deun Deun,
For me, it works too except when I move the Low Pass slider. It makes a sort of bad echo when I move it instead of cutting a range of frequency.
The High Pass slider works well.
geposted Thu 26 Oct 06 @ 9:56 am
If you hear a bad noise when changing sliders, it's because the inlined algorythm isn't optimized enough, and FFTs are very heavy to be computed for a CPU, even for the latest ones...
This is why I'm trying to use FFTW ( http://www.fftw.org ), but after building DLLs they don't work... I mean I can't link the library of VDJ won't load the plugin at all. I don't know why this happens, but I MUST use FFTs, which aren't included anymore in the new SDK.
geposted Thu 26 Oct 06 @ 2:53 pm
