Topic: Toggle headphones on/off
Hi everyone,
I own a Hercules DJ Control mp3, and I'm using Virtual Dj to mix my tracks. The software is pretty stable and fast, however there is one basic thing i haven't been able to achieve. The headphones button (the one which allows you to listen the next track to be mixed in the headphones) must be pressed in order to hear it. As soon as you release it, you stop listening to it. So, isn't there a way to TOGGLE (switch on/off) the headphones button?
Thanks a lot
geposted Mon 06 Nov 06 @ 10:59 am
sbangsPRO InfinityMember since 2004
try pressing it hard it might stay depressed and check the control pannel for the software for any settings
i wasnt aware the control version had headphones
worst case senario try bluetack lol?
geposted Mon 06 Nov 06 @ 11:47 am
lol, i'm afraid bluetack won't do the job...
seriously, isn't it possible to just turn on/off headphones output for a deck? If not, how you guys do mix? You need to keep the button pressed all through the mix?
geposted Mon 06 Nov 06 @ 11:56 am
i use mk2 thats got a selector knob
i dint think the control version even had a sound card
iv looked it up on google and it says it cant do headphones are you sure your using the djc mp3 control ?
not the mk2
im very confused
geposted Mon 06 Nov 06 @ 12:07 pm
Hi there,
I'm using the Control version (http://www.hercules.com/showpage.php?swcty=UK&p=126&b=0&f=0), which doesn't have a sound card. I'm using an external sound card. The djc mp3 control has a button (in fact two, one for each deck) that enables me to preview that desk in my headphones. In example, when i use the control with Traktor, i can assign that button to the "Cue" button, therefore swithing on/off the desks i want to prelisten in my headphones. In Traktor's midi mapping settings, i can set that button to "toggle", which is exactly what i want to achieve in virtual dj.
Does it make sense now? Sorry if i didn't make myself clear enough.
thanks for your help.
geposted Mon 06 Nov 06 @ 12:33 pm
kool i get you
select headphone mode in virtual dj
in the sound setup that way you can always listen :)
geposted Mon 06 Nov 06 @ 12:51 pm
sorry, "headphone mode"?
In Settings/Sound Card i have the "Headphones on 4.1 rear output" checked, which is ok (if i press and KEEP PRESSED the Cue Seletion button on my djc mp3 i can hear the cued deck on my headphones). However, I still need to keep it pressed. As soon as i release the button, i can't hear anything on my headphones.
My problem is not being able to route sound to the headphones. That's working fine. My problem is how to keep hearing my cued track on my headphones without needing to keep my finger pushing the djc mp3 button.
thanks again.
geposted Mon 06 Nov 06 @ 1:05 pm
erxonPRO InfinityMember since 2003
skyfxl, I know you're trying to be helpful and like to write a lot, but I'd personally rather hear a straightforward answer to the matter when looking for an answer on a forum than discussing headphone ability with that particular version.
The matter here is a known problem (or at least I've read already about it on the forum) which probably can be solved, so my advice would be to search for it either in Software Technical Support forum or better yet Hardware Technical Support. Try different search keywords headphone+button, cue problem/button + hercules, etc. to find the topic.
If you're using Hercules as a MIDI device, it's possible to assign (and modify) any control to any function of VDj (under Settings > Remote Control > MIDI > Config...). If it's possible with your version I don't know, but I suggest you do a little research on those forums, because it was probably already discussed :) Or wait for an answer from someone with experience with this controller.
Regards,
e
geposted Mon 06 Nov 06 @ 1:33 pm
ciocePRO InfinityMember since 2004
thanks again.
This is a limitation of your Virtual DJ 3.4 DJ console version http://www.virtualdj.com/products/djcedition.html
You can delete this limitation and make free your finger only with PRO version http://www.virtualdj.com/purchase/
@ erxon - Midi option work only in PRO version.
geposted Mon 06 Nov 06 @ 2:00 pm
Thanks, that's what I wasn't sure of. :)
geposted Mon 06 Nov 06 @ 2:47 pm
geposted Mon 06 Nov 06 @ 3:19 pm
DJ FORMATPRO InfinityModeratorMember since 2003
it works ok VDJ Pro 4.1
geposted Mon 06 Nov 06 @ 5:36 pm
Gracias
geposted Mon 06 Nov 06 @ 10:37 pm
