Topic: Fine Tuning the Tempo Range
SupaconPRO InfinityMember since 2005
Is there any way to fine tune the tempo range, other than selecting between 8,12 and 33 percent?
It'd be nice to be able to select +/- 100%, like on some CD players, and then you get a really neat braking effect, or to be able to change it to something really fine like 6 or 4 percent for really accurate adjustments.
Also, can you add a button in a skin or a keyboard shortcut to switch between these ranges?
geposted Sun 19 Nov 06 @ 11:59 pm
DJKicePRO InfinityMember since 2005
Config -> Options -> Pitch Range.
VDJ only goes upto +34/-34 % as far as i know.
You could try going threw the keyboard shortcuts and making these for yourself. Just assign a key and select what you want it to do(so in your case change pitch range). I think however it might only be possible threw options.
There might be a slight chance you could set it to +/-100% using shortcuts but not entirly sure.
geposted Mon 20 Nov 06 @ 6:03 am
