Forum: VirtualDJ Skins
Topic: MiniScratch 1280x800 (request)
Unfortunately I cannot Get Skin Resizer to work properly can we get a MiniScratch 1280x800...... The other question is ..... Can you add a Native Button for Reverse (I'm a BCD2000 User)
geposted Tue 21 Nov 06 @ 6:38 pm
listen2PRO InfinityMember since 2005
i was thinking of that ;) as far as i know the resizer only does the Bmp not the XML so all code would have to be adjusted. the reverse option i can toss in no problem. Any suggestions for a spot? i think i going to add effects selector and hot cues somewhere also.
geposted Tue 21 Nov 06 @ 9:16 pm
HaywardPRO InfinityMember since 2005
I have to say this skin does not require a lot of work, so you should be careful about the HOT CUES especially since they may ruin the look/functionality of your excellent skin and I have not read that users really want these ( I could be wrong.)
You could put the 'reverse' button opposite the 'keylock' button on each deck.
You could put a selectable panel with eq faders/effects/cues/ and still maintain the original 'look'.
Also, you may consider moving the 'beat meters' closer together to be more effective.
I still love the sking the way it is, please take no offense to my suggestions.
geposted Tue 21 Nov 06 @ 9:38 pm
none taken, i was just looking at the area that displays the cue time, the buttons that are there are small as hell and probably too hard to actually make use out of. Everything i think of with the skin is towards function, the hot cues i sometimes find myself wanting to use more then one cue point in a song but your right it is rare. I also find myself looking to quickly change effects and moving the cursor down to the effects tabs sometimes does not happen as quick as i would like. Beyond that, have no fear i will not mess with the function of it. As soon as i finish it, i might work on a 1200x800.
i'm working on these functions tonight ;)
geposted Wed 22 Nov 06 @ 1:32 am
YES PLEASE 1280x800 PLEASE ITS MY FAVORITE SIZE
geposted Wed 22 Nov 06 @ 4:13 am
Happy holidays!
Coming very soon Miniscratch 1280x800
I'm just finishing up a few tweaks
beyond that a complete redo for 2007
geposted Mon 18 Dec 06 @ 2:48 pm
Bro Thank you so much much appreciation.. Can you add in a HOT SPOT for reverse mode?
geposted Mon 18 Dec 06 @ 9:13 pm
geposted Mon 25 Dec 06 @ 3:53 pm
THANKS YOU SOOO MUCH YOU ARE THE BEST.....
geposted Tue 02 Jan 07 @ 6:06 pm
vizafuHome userMember since 2007
hello, thannks for the skin
geposted Wed 03 Jan 07 @ 7:37 am
well thanks... but the skin is intended for licensed "professional" users , so if you do have it then you owe me a drink.
geposted Wed 03 Jan 07 @ 2:18 pm
Yeah i wanna Drink as well, cause this skin has too much Bang for 1 Drink...
geposted Fri 05 Jan 07 @ 8:51 pm
