My trial version of 4.1 is almost up and is till dont have this thing working correctly.
i still have stuttering problems like every 3 seconds when playing a song on TCV. i tried messing with all the different setting under the performance tab and nothing seemed to fix it.
i'm using
Stanton Str8-80 turntables
Stanton Sk-6 Mixer
MK2
TCV
i just noticed that when i dont hook up the Mk2 and i use VDJ set to simple soundcard the same thing happens (stuttering like every 3 seconds during a song) and when i play sound files from yahoo Music i also get like a stuttering effect.
my machine is a DELL 2.97 GHZ w/ 512 Kingston RAM
ANY IDEAS??
THANKS!!
i'm using
Stanton Sk-6 Mixer
MK2
TCV
ANY IDEAS??
THANKS!!
geposted Mon 27 Nov 06 @ 10:04 pm
In Proformces,,, Try changing Master Tempo setting to Fast...
geposted Mon 27 Nov 06 @ 11:23 pm
dells have been giving problems with vdj!!!!!!
geposted Mon 27 Nov 06 @ 11:32 pm
tried this.... comon skyfxl where are you???
geposted Tue 28 Nov 06 @ 5:06 am
what video card do u have?
geposted Tue 28 Nov 06 @ 6:25 am
lower your proformance tab
aslo
try this for buffer info and what settings to choose you cannot use the mk2 as a card you must use its asio drivers
have a read
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
tada
sorry for being slow
dam collage blocked vdj again!
but no longer lol;)
geposted Tue 28 Nov 06 @ 11:04 am
sly , everything can't be a performance issue can it? ;)
i was asking for the video card because i had a similar problem and it was a power issue. Does the MK2 have it's own power adapter?
geposted Tue 28 Nov 06 @ 2:23 pm
90% of computer problems are proformance related
well so iv been made to study lol
thats the issue i had with timecode before i made that guide so i thought i would sugest :)
i aslo find it runs alot better with the power cable :)
geposted Tue 28 Nov 06 @ 3:13 pm
i didnt read that it happens with the internal card too.
what happens if you play window media player or some other audio app.?
So this only happens in vdj?
geposted Tue 28 Nov 06 @ 4:08 pm
