I have a Hercules DJ Console that I purchased in 2003..
Will this console work properly with VDJ4.1 Or do I need to buy a updated one?
I hooked it up, updated the software from Hercules sight, installed VDJ's Mapper and it not running well.
geposted Tue 28 Nov 06 @ 2:08 pm
mk1 or mk2 ?
geposted Tue 28 Nov 06 @ 3:12 pm
skyfxl wrote :
mk1 or mk2 ?
2003 => Mk1 ;-)
geposted Tue 28 Nov 06 @ 3:57 pm
koolio
either way it should work just fine with version 4 no upgrades needed
make sure u have the right mapper :)
geposted Tue 28 Nov 06 @ 4:42 pm
The controller I have was out before Hercules had a controller without a sound card..
Mine has a sound card. It doesn’t display any ware on the unit ‘MK1’ or ’MK2’ ..
The mapper is the latest. (djc)
The latest software from Hercules (2006_CMK2_1)
http://www.hercules.com/index_products.php?swcty=UK
geposted Tue 28 Nov 06 @ 5:56 pm
There are no markings on the unit that indicates MK1 or MK2
The logo at the top center of the controller only reads (Dj Concole)
I looked though the original install disc Found this.
Installation CD Version 1.0
What Mapper do I down load.. This thing is really unstable..
geposted Tue 28 Nov 06 @ 8:15 pm
Ok …
1) I hooked up the controller without using it's sound card and it worked perfect..
2) I use the controllers sound card and all hell breaks loose…
Motherboard; Intel BOXD955XBKLKR 955XE P4/P4EE/Pentium XE LGA775 1066FSB DDR2 ATX w/Audio, Gigabit LAN, RAID/Serial ATA Retail
Processor; Intel Pentium® 4 631 Processor Prescott 3.0GHz, 800MHz FSB, Socket 775, 2MB
Ram; OCZ OCZ28002048ELDCGE-K 2GB Kit DDR2-800 PC2-6400 Enhanced Latency Gold Edition Dual Channel Memory
Video Card; Sapphire Radeon X1600 PRO PCI Express 512MB DDR2 Video Card w/TV-Out, DVI & VGA
geposted Tue 28 Nov 06 @ 11:45 pm
which version of virtual dj is on the isnstall disk?
geposted Wed 29 Nov 06 @ 12:20 pm
1.6.0.0
geposted Wed 29 Nov 06 @ 5:01 pm
you have hercules dj console (mk1). It will not work with mk2 mapper. I think there is a mapper specifically for the mk1. Use djc mapper 4.0 by dj cel ( must be used with vdj 3.4 or 4.0).
geposted Wed 29 Nov 06 @ 5:26 pm
Pick One...
Hercules DJC Mapper v4.1.1
Description:
v4.1: It uses the new Mapper SDK for VirtualDJ v4.1
v4.1.1: some bugs corrected
Hercules DJC Mapper v4.0 for VirtualDJ v3.4 and v4.0
Description:
Now include a new graphical interface to map the DJ Console 1, DJ Control mp3 & DJ Console MK2:
* You can change the data in live
* You can save/load settings in different files
* You can affect the function effect_slider() on the stick (affect the two opposite button)s
* You can use the jog to move a slider
Mapper for DJC mk2
Description:
For use with an external mixer.
In my Blog you can find more information.
DJC Mapper v1.1
Description:
Loop 4,8,16 beats
Function sync() for Auto Beat
New big button CUE {cue_stop() + goto_cue()} (only use the button play on the dj console for this new function)
Read the browser until playlist
Description:
Description:
Mapper for DJC mk2
Description:
DJC Mapper v1.1
Description:
Loop 4,8,16 beats
geposted Wed 29 Nov 06 @ 5:38 pm
Where do I get this mapper? My MK2 has lost looping functionality with VDJ 4.0
geposted Tue 05 Dec 06 @ 4:27 pm
geposted Tue 05 Dec 06 @ 4:55 pm
skyfxl wrote :
http://www.virtualdj.com/addons/tools.html
Which mapper is for mk1???
Mine is still not working.
geposted Tue 05 Dec 06 @ 7:43 pm
