Forum: Old versions
Topic: Distortion when mixing with versionon 4.1
I've been using VDJv2 for ages with my Hercules DJ Console MK1, just got VDJv4.1 and there are loads of problem.
When playing track a, when bringing in a song in on track b, any adjusments to the High/Mid/Low knobs, the crossfader or the pitch, gives a feint distorted rumbeling sound. It kind of sounds liek thunder or a hillcopter in the background.
I've updated all the drivers but it makes no difference.
Any ideas?
geposted Wed 29 Nov 06 @ 10:51 pm
geposted Wed 29 Nov 06 @ 10:55 pm
sbangsPRO InfinityMember since 2004
Any ideas?
this sounds like an issue with current noise check your computer and cables are grounded
geposted Wed 29 Nov 06 @ 11:04 pm
I found that as soon as I selected master temple the same thing happened to me... I even changed performance down and it still happened.
The controller works perfect if you don’t utilize the sound card..
Witch mapper are you using?
geposted Wed 29 Nov 06 @ 11:59 pm
Not sure, how do I nfind out which mapper I am using?
geposted Fri 01 Dec 06 @ 9:06 pm
As a no license user you aren't using any mapper.
geposted Sat 02 Dec 06 @ 2:14 am
indeed..
geposted Sat 02 Dec 06 @ 11:02 am
