Tried both of the resizing tools offered by Virtual DJ to resize the 4.x basic skin to 800x600
but with Both
when tried to open up the new (resized) skin in Config:
got the same error message:
"Invalid Skin File (error line 15 in the xml)
How can I fix it?
but with Both
How can I fix it?
geposted Sun 03 Dec 06 @ 10:26 am
try another skin?
geposted Sun 03 Dec 06 @ 12:01 pm
Which skin is the closest to 4.xx but with 800x600 resolution?
geposted Sun 03 Dec 06 @ 9:55 pm
Check that your logo size is no smaller that 0 x 17
geposted Tue 05 Dec 06 @ 3:10 pm
geposted Tue 05 Dec 06 @ 7:31 pm
Thanks for the Photo makes it easier :)
after you check/change the logo size make sure that, it doesnt overlap into anything
geposted Tue 05 Dec 06 @ 11:25 pm
Yes like the clock
geposted Wed 06 Dec 06 @ 1:02 pm
